Icemaker Makes Ice Only Infrequently. If I Move The Full Bar Forward It Will Make One Cycle. I Put Ice Cube Trays In And They Freeze Quickly. Any Thoughts?
What did you call "Full Bar"?
The model number you posted does not come up. Verify and repost it please.
Originally Posted by: louisechas@aol.com  model is PSS26SGRCSS Loise, "If I Move The Full Bar Forward It Will Make One Cycle." indicates an issue in the ON/Off lever mechanism or the tension spring between the "paddle" and the base of the control module(front of ice maker) You may want to check That first. There are no repairable or replaceable parts, and the ice maker will need to be replaced Part number: AP4345120
