doug1026
#1 Posted : 12 years ago
doug1026
I have a GE Spacemaker microwave with a cracked door frame. I have replaced it before a number of years ago. Apparently, the heat from the range below must cause the plastic outer door frame to crack over time....not a great design.
In any case, I cannot remember how to remove the door handle, which appears to be secured with two screws -- one visible and easily accessible and the bottom one inside and not easily accessible.
Can anyone tell me how to access the bottom screw so that I can remove the old frame and install a new one?
scott5495
#2 Posted : 12 years ago
scott5495
open the door. there is a plastic frame that covers the two latches. this frame
is one piece and covers the inside door frame. take a small flat screwdriver
and place between the metal and the plastic frame and carefully pry the plastic frame cover outward. the frame will pop out of the door and over the latches. you will see your two handle screws.
doug1026
#3 Posted : 12 years ago
doug1026
Thanks for your help.
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 2 years ago
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 3 years ago
Change Microwave Bulb (Microwave Repair)
GE Microwave Lighting Issue (Microwave Repair)
by HDL 3 years ago
GE Microwave JVM1540DM4 WW - Looking for wiring diagram (Microwave Repair)
by shotgnz 3 years ago
GE Microwave Not turning table nor heating JVM1540DM4WW (Microwave Repair)
by gnieciag 4 years ago
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 4 years ago
Samsung Over-the-Range Microwave (Microwave Repair)
by smitty121064 4 years ago
GE Microwave tripping breaker (Microwave Repair)
by Bafire0731 6 years ago
ge microwave door (Microwave Repair)
by david habenicht 6 years ago
Samsung over range microwave no power (Microwave Repair)
by toolmaker129 6 years ago
GE Microwave Not Heating (Microwave Repair)
by JIMMIEM 7 years ago
GE microwave exhuast fan won't shut off (Microwave Repair)
by diy_dave54 7 years ago
GE Microwave Start and Quick Start Buttons Don't Work. (Microwave Repair)
by garypatterson 8 years ago
GE Microwave - dead (Microwave Repair)
by bfamily 8 years ago
