there is no power at all, I thought it might be an electrical problem, so plugged it elsewhere and still nothing?
A model number may help others help you.
By no power do you mean that everything is off, even the fridge lights? |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A model number may help others help you.
By no power do you mean that everything is off, even the fridge lights? yes. I have plugged it into another outlet and checked the breaker, but nothing happens. Light doesn't even go on?
Originally Posted by: la98  yes. I have plugged it into another outlet and checked the breaker, but nothing happens. Light doesn't even go on? yes. I have plugged into a working outlet and checked breaker, but nothing happens, light doesn't even go on?
Need a model number? Find your model number - AppliancePartsPros.comThe first place to start is to check for power in the unit using a meter. Check where the line cord attaches to the units wiring, could be just a bad line cord. If there is no power then check the line cord using ohms to see if it is bad. |
