jpg6573
#1 Posted : Tuesday, April 2, 2013 7:16:53 PM(UTC)
jpg6573
My GE dryer had an uncontrollable squeaking. I thought it was the rear assembly but it turns out I think it was the front glide because the plastic glide was missing a section thus making the drum rub against some wires. After using it to fluff up some clothes, sparks flew out. I replaced the glide and the rear assembly was still good. After turning the power back on, the dryer won't start but there's power to the dryer. Is it not starting due to those wires being exposed and arcing? Is it repairable?
Joe / APP Team
#2 Posted : Wednesday, April 3, 2013 11:46:18 AM(UTC)
Joe / APP Team
JPG, Yes, if the wire harness was rubbing against the drum, the wires could be damaged and shorted (the arcing/sparks). The door switch circuit has to be completed in order for the dryer to start and run, so you'll need to check and repair the wires to the door switch, using wire cutters and shrink wrap or bullet connectors, and make sure the wires are secured in the retainer clip before you start the dryer again.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
