-Ronin-
#1 Posted : Friday, March 8, 2013 5:37:40 AM(UTC)
-Ronin-
I'm having an issue with my 10+ year old refrigerator where its running but its not getting cold. I did a little research to see what the problem might be at stumbled upon this page:
http://www.justanswer.com/appli...ing-appears-running.html
This is almost the exact situation I have. I tried removing the back panel and taking a look at the compressor. I dont think its running but i could be wrong. When i put my hand on it I felt a slight vibration, no heat. But when i removed the power cable from the nearby cooling fan and then put my hand on the compressor I felt no vibration, so I'm guessing that the compressor or the relay is bad.
Any help is appreciated. Attached are some pictures I took of the compressor this morning.
-Ronin- attached the following image(s):
#2 Posted : Saturday, March 9, 2013 5:18:54 AM(UTC)
If the condensing fan by the compressor is running, you probably have voltage to the compressor. If so, you most probably have a blown open compressor, or a bad start device. Without a meter to check things, I would try replacing the start device. If you remove it a shake it and it rattles, that confirms it, but usually they don't totally blow open.
-Ronin-
#3 Posted : Saturday, March 9, 2013 6:24:53 AM(UTC)
-Ronin-
Ok. I was able to remove the start device and it was indeed ratlling. When i disassembled it the inside components were all crumbled, so i'm guessing the start device went bad? If i were to get a new start device it would be this part right:
http://www.appliancepartspros.c...e-8201769-ap3961332.html
#4 Posted : Sunday, March 10, 2013 12:46:57 AM(UTC)
This site shows part # 8201769. Before ordering,note which colored wires go to which pins on the device and try to measure the resistance of the compressor windings, the resistance from the top, or bottom terminal to either side by side terminals should be between 3 and 6 ohms.
-Ronin-
#5 Posted : Monday, March 11, 2013 7:32:14 AM(UTC)
-Ronin-
Sounds good. I've already ordered the part and hopefully this will resolve the issue. I'll let you know how it goes.
-Ronin-
#6 Posted : Tuesday, March 12, 2013 7:32:52 PM(UTC)
-Ronin-
The part arrived today and after installing the new start relay the refrigerator started generating cold air. Thanks again for your help.
#7 Posted : Wednesday, March 13, 2013 1:00:21 AM(UTC)
You are wellcome.
Whirlpool Refrigerator not cold enough (Refrigerator & Freezer Repair)
by bsmcc 3/22/2016 6:52:44 AM(UTC)
Whirlpool Refrigerator not cold (Refrigerator & Freezer Repair)
by medemers 7/29/2012 8:43:09 AM(UTC)
by molly1212 3/18/2012 8:55:27 AM(UTC)
