When I try to set temp for oven or broil - the clock display lets me pick the temp (oven) then goes blank for a second then goes back to the clock. Same if I chose broil. Thanks
Originally Posted by: urbanrover  When I try to set temp for oven or broil - the clock display lets me pick the temp (oven) then goes blank for a second then goes back to the clock. Same if I chose broil. Thanks Urbanrover, If you can select a cycle and temperature, and have no error codes(F1,F2,F3, etc.) Then the issue is in the ERC/Clock Part number: AP2970621
The eeprom in the clock is not "seeing" the relays close or voltage passing through the circuit, so it misinterprets the input and reverts back to the time of day mode.
Thank you for your prompt reply.
Originally Posted by: urbanrover  Thank you for your prompt reply. You're welcome !! Good Luck, and Thanks
