urbanrover
#1 Posted : Thursday, March 7, 2013 7:11:20 AM(UTC)
urbanrover
When I try to set temp for oven or broil - the clock display lets me pick the temp (oven) then goes blank for a second then goes back to the clock. Same if I chose broil.
Joe / APP Team
#2 Posted : Thursday, March 7, 2013 7:45:58 AM(UTC)
Joe / APP Team
Urbanrover, If you can select a cycle and temperature, and have no error codes(F1,F2,F3, etc.) Then the issue is in the ERC/Clock
Part number: AP2970621
The eeprom in the clock is not "seeing" the relays close or voltage passing through the circuit, so it misinterprets the input and reverts back to the time of day mode.
urbanrover
#3 Posted : Friday, March 8, 2013 11:18:54 AM(UTC)
urbanrover
Thank you for your prompt reply.
Joe / APP Team
#4 Posted : Friday, March 8, 2013 11:59:22 AM(UTC)
Joe / APP Team
You're welcome !!
Good Luck, and Thanks
