AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Washer agitator not working and will not spin
I have retried washer and agitator is working.The machine doesn't spin, but water fills and pumps out.Could this be a coupler hub assembly problem?
Unfortunately I do not have any experience with such washer.
Maybe somebody else on the forum can help you better.
Gene thanks for trying.I hope that someone else might have worked on the smaller type washer.
is this an apartment size washer that rolls to sink 110 volts? are you saying machine does fill + agitate +drain. the only thing it does not do is spin?l
This is like the large washer.Is similiar to the stack units except it is just the washer. I have narrowed it down to a solinoid that shifts from spin to agitate cylces or a defective timer. I don't think it's the timer as it doesn't spin when you put it in the separate spin cycle.How do you test out a solenoid with the following specs?AC127V50/80,150mA.If you have any other suggestions I would like to get this running again.Thank You
There is a tech sheet under the top .. it will have the testing and trouble shooting steps...
Washer Repair
