bobbertj
#1 Posted : Friday, February 1, 2008 8:40:26 AM(UTC)
bobbertj
I have retried washer and agitator is working.The machine doesn't spin, but water fills and pumps out.Could this be a coupler hub assembly problem?
#2 Posted : Friday, February 1, 2008 1:38:51 PM(UTC)
Unfortunately I do not have any experience with such washer.
Maybe somebody else on the forum can help you better.
bobbertj
#3 Posted : Friday, February 1, 2008 5:07:37 PM(UTC)
bobbertj
Gene thanks for trying.I hope that someone else might have worked on the smaller type washer.
misterfixall
#4 Posted : Saturday, February 2, 2008 3:34:47 PM(UTC)
misterfixall
is this an apartment size washer that rolls to sink 110 volts? are you saying machine does fill + agitate +drain. the only thing it does not do is spin?l
bobbertj
#5 Posted : Sunday, February 3, 2008 5:25:06 AM(UTC)
bobbertj
This is like the large washer.Is similiar to the stack units except it is just the washer. I have narrowed it down to a solinoid that shifts from spin to agitate cylces or a defective timer. I don't think it's the timer as it doesn't spin when you put it in the separate spin cycle.How do you test out a solenoid with the following specs?AC127V50/80,150mA.If you have any other suggestions I would like to get this running again.Thank You
bambiblaster
#6 Posted : Friday, April 4, 2008 7:43:26 PM(UTC)
bambiblaster
There is a tech sheet under the top .. it will have the testing and trouble shooting steps...
