corylus
#1 Posted : 16 years ago
corylus
Our control panel on our undercounter kitchenaid is malfunctioning. Only normal lights up and cancel. When you hit normal then start -nothing. If you hit cancel it cycles out just fine. I flipped the circuit breaker opened the control panel and cleaned the contacts. Tried it again and tested each button and each lit up. Tried normal mode and start and it started and I canceled. Loaded it that night and hit normal and start and normal lights up but no start. Once again the only lights functioning will be normal and cancel. Is it the "touch panel" itself or the control board (the brain)? thanks ,Corylus
csager
#2 Posted : 16 years ago
csager
There are several of us with the same type of problem. Look at some of the other Kitchenaid KUD posts for a tech sheet and troubleshooting instructions. I have the same basic problem and I thought it was the control board. But, after inspecting the ribbon cable between the panel and board and finding some corrosion and performing a short cycle test where all the cycles worked I am going to replace the panel. I'll know next week if I was right.
Guest
#3 Posted : 2 years ago
Guest
Rank: Guest
United States
My dish runs no water and flashes CL
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD about a year ago
GE Dishwasher Troubles (Dishwasher Repair)
by Jeff Demers 4 years ago
Frigidaire Dishwasher Trouble Shooting (Dishwasher Repair)
by CrazyBoom1 10 years ago
Dishwasher troubleshooting (Dishwasher Repair)
by garqua 13 years ago
Dishwasher Trouble shoot (Dishwasher Repair)
by dsfball 14 years ago
Dishwasher trouble (Dishwasher Repair)
by gassman 14 years ago
Bosch Dishwasher Troubles (Dishwasher Repair)
by lakehouse2 14 years ago
ge profile dishwasher trouble (Dishwasher Repair)
by MikeyG 15 years ago
by clarkmailbox 16 years ago
bosch dishwasher troubleshoot manual (Dishwasher Repair)
by harold g 17 years ago
Bosch SHU dishwasher troubleshooting chart (Dishwasher Repair)
by StratLou 18 years ago
