corylus
#1 Posted : Thursday, October 1, 2009 11:14:49 AM(UTC)
corylus
Our control panel on our undercounter kitchenaid is malfunctioning. Only normal lights up and cancel. When you hit normal then start -nothing. If you hit cancel it cycles out just fine. I flipped the circuit breaker opened the control panel and cleaned the contacts. Tried it again and tested each button and each lit up. Tried normal mode and start and it started and I canceled. Loaded it that night and hit normal and start and normal lights up but no start. Once again the only lights functioning will be normal and cancel. Is it the "touch panel" itself or the control board (the brain)? thanks ,Corylus
csager
#2 Posted : Thursday, October 1, 2009 4:35:04 PM(UTC)
csager
There are several of us with the same type of problem. Look at some of the other Kitchenaid KUD posts for a tech sheet and troubleshooting instructions. I have the same basic problem and I thought it was the control board. But, after inspecting the ribbon cable between the panel and board and finding some corrosion and performing a short cycle test where all the cycles worked I am going to replace the panel. I'll know next week if I was right.
Guest
#3 Posted : Friday, September 15, 2023 1:06:22 PM(UTC)
Guest
Rank: Guest
United States
My dish runs no water and flashes CL
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
GE Dishwasher Troubles (Dishwasher Repair)
by Jeff Demers 10/20/2020 3:52:06 AM(UTC)
Frigidaire Dishwasher Trouble Shooting (Dishwasher Repair)
by CrazyBoom1 5/25/2015 8:52:10 AM(UTC)
Dishwasher troubleshooting (Dishwasher Repair)
by garqua 6/2/2012 4:25:14 AM(UTC)
Dishwasher Trouble shoot (Dishwasher Repair)
by dsfball 5/2/2011 1:27:15 PM(UTC)
Dishwasher trouble (Dishwasher Repair)
by gassman 2/17/2011 4:10:42 PM(UTC)
Bosch Dishwasher Troubles (Dishwasher Repair)
by lakehouse2 11/30/2010 7:06:31 AM(UTC)
ge profile dishwasher trouble (Dishwasher Repair)
by MikeyG 4/11/2010 6:48:31 PM(UTC)
by clarkmailbox 9/23/2009 11:14:33 AM(UTC)
bosch dishwasher troubleshoot manual (Dishwasher Repair)
by harold g 4/10/2008 10:56:41 AM(UTC)
Bosch SHU dishwasher troubleshooting chart (Dishwasher Repair)
by StratLou 8/29/2007 10:40:45 AM(UTC)
