Shay Hughes
#1 Posted : Tuesday, February 12, 2013 6:55:12 AM(UTC)
Shay Hughes
I have an LG DLE2514W electric dryer. The dryer will be running fine and just shut down. I have checked incoming power and checked for loose terminations. I checked heating element and made sure all ducting was clear of any obstructions. I think the problem is in the control board but I wanted to ask for suggestions or possible testing procedures before I start replacing parts.Any help with this would be greatly appreciated.
Thanks,
Shay
Simon / APP Team
#2 Posted : Tuesday, February 12, 2013 9:48:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you can restart the dryer right after it's stops, then it's most likely the control board.
If it won't start for a few minutes - bad motor.
Control Part number: 6871EC1121C
board
The motor Part number: 4681EL1008A
Here are the breakdown diagrams and parts for LG DLE2514W - AppliancePartsPros.com
Post the results.
Simon.
dryer shuts down on high heat (Dryer Repair)
by wwager 10/2/2017 12:04:47 PM(UTC)
Dryer shuts down (Dryer Repair)
by Shay Hughes 2/12/2013 10:36:01 AM(UTC)
Frigidaire dryer shuts down (Dryer Repair)
by richappy 5/15/2012 2:12:38 PM(UTC)
Maytag Electric Dryer Shuts Down (Dryer Repair)
by walkthesky 10/7/2010 9:17:37 AM(UTC)
Electrolux dryer shuts down immediately (Dryer Repair)
by firest02 9/10/2010 5:11:22 PM(UTC)
by 88dave 12/5/2009 1:51:25 PM(UTC)
HP fault code. dryer shuts down (Dryer Repair)
by panman 1/4/2009 4:56:22 PM(UTC)
heat dryer shuts down (Dryer Repair)
by basketballcoach322 12/24/2008 10:19:57 AM(UTC)
by partsman 7/27/2008 6:19:03 PM(UTC)
Dryer shuts down just before cooldown (Dryer Repair)
by mrmeld 1/20/2008 11:12:07 AM(UTC)
