I have an LG DLE2514W electric dryer. The dryer will be running fine and just shut down. I have checked incoming power and checked for loose terminations. I checked heating element and made sure all ducting was clear of any obstructions. I think the problem is in the control board but I wanted to ask for suggestions or possible testing procedures before I start replacing parts.Any help with this would be greatly appreciated.
Thanks, Shay
Groups: APP Team
Hi. If you can restart the dryer right after it's stops, then it's most likely the control board. If it won't start for a few minutes - bad motor. Control Part number: 6871EC1121C
