basketballcoach322
#1 Posted : Wednesday, December 24, 2008 10:19:57 AM(UTC)
basketballcoach322
I have a Roper dryer and I just recently replaced the push switch. Since replacing this switch the dryer now continues to shut down when it starts to get hot. Is this a thermostat or heat coil issue?
libertyappl
#2 Posted : Wednesday, December 24, 2008 10:53:22 AM(UTC)
libertyappl
Probably a cycling thermostat. Please post your model number for more information.
Nat
misterfixall
#3 Posted : Wednesday, December 24, 2008 1:33:24 PM(UTC)
misterfixall
did you check to see dryer is venting to outside properly, should have plenty of air blowing to outside, if not check for blockage or kinked vent hosing
