Burde Kamath
#1 Posted : Monday, February 11, 2013 4:08:13 AM(UTC)
Burde Kamath
Microwave fuse blows out when I touch the keypad for heating a food item, indicating shorting somewhere. How can I find out where the shorting occurs and repair it?
Simon / APP Team
#2 Posted : Monday, February 11, 2013 1:49:51 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is a bad hi-voltage capacitor Part number: WB27X10011
To check it unplug the unit, discharge the capacitor using two screwdrivers with the plastic handles (cross screwdrivers touching both capacitor's contacts).
Using the multimeter check the resistance, first between the contacts (with all wires removed from the capacitor). On the analog meter you should see the spike followed by infinity.On the digital-no continuity.
Next check each contact to the ground. Should be no continuity.
Replace the capacitor if it's bad.
Here is the breakdown diagram and Microwave parts for GE JVM1740DM2WW - AppliancePartsPros.com
Post the results.
Simon.
Microwave repair (Microwave Repair)
by Tim Swanson 11/20/2013 1:20:16 PM(UTC)
Is this microwave repairable (Microwave Repair)
by kalt 12/31/2012 9:41:35 AM(UTC)
Microwave Repair (Microwave Repair)
by ramara 12/4/2012 1:13:52 PM(UTC)
microwave repair help (Microwave Repair)
by dia 10/1/2012 1:08:16 PM(UTC)
by gskill@bellsouth.net 8/1/2012 3:21:05 AM(UTC)
by JO D 12/11/2011 4:17:55 AM(UTC)
by DANLUDLOW 11/28/2011 7:28:09 AM(UTC)
microwave repair (Microwave Repair)
by cking1269 11/4/2011 9:04:36 AM(UTC)
kenmore microwave repair (Microwave Repair)
by ploou 11/3/2011 10:42:00 AM(UTC)
GE microwave repair help (Microwave Repair)
by Tom in Crozet 4/28/2011 7:07:55 PM(UTC)
Microwave Repair with loud noise (Microwave Repair)
by Faith4220 12/26/2010 11:20:14 AM(UTC)
by stillyrabbit 12/22/2010 10:52:18 AM(UTC)
by bloop 11/4/2010 8:33:04 AM(UTC)
Is old microwave repairable? (Microwave Repair)
by sadiehaflinger 11/17/2009 9:51:36 AM(UTC)
by allene 10/12/2009 7:58:42 AM(UTC)
