Need to know which part is the control panel module. w1026902 or w10392998. Can't tell from parts list. Thanks
Both work as electronic controls. I would order the less expensive one because I don't think it is worth spending what the more expensive one cost to fix this machine.
If you order from this site and the part does not fix the problem you can return it.
