drewmar
#1 Posted : Wednesday, September 30, 2009 1:37:00 PM(UTC)
drewmar
it heated up and ran a while then stopped. now it starts then stops within a minute
#2 Posted : Wednesday, September 30, 2009 2:37:43 PM(UTC)
Can you restart it right away or do you have to wait a while for it to restart.
If you have to wait then often this is a motor problem.
The motor could be overheating and tripping it's internal thermal cut-out.
It then has to cool down so the cut-out resets before it will start again.
jcpendergast
#3 Posted : Sunday, October 4, 2009 5:55:32 AM(UTC)
jcpendergast
I had this problem and fixed it by replacing the gas coils. There are two, a primary and secondary. The primary starts the gas flow, and allows the secondary to take over. If the secondary coil fails, the system shuts down. I replaced them both for about $20.00. Hope this helps.
whirlpool dryer starts then stops in twp seconds (Dryer Repair)
by ptk100 5/6/2014 6:20:37 PM(UTC)
Dryer Starts then Stops (Dryer Repair)
by tbakker 10/8/2012 4:44:31 PM(UTC)
Dryer starts then stops when drum is manually moved (Dryer Repair)
by WinePoet 2/19/2012 11:58:57 AM(UTC)
Kenmore HE3 Dryer starts then stops (Dryer Repair)
by nowhere 1/13/2012 8:32:59 PM(UTC)
dryer starts then stops (Dryer Repair)
by John Herrera 11/22/2010 8:54:47 AM(UTC)
by skinners 10/16/2010 7:39:23 AM(UTC)
by Earl w 8/15/2010 9:08:11 AM(UTC)
dryer starts then stops and makes noises (Dryer Repair)
by karenmpls 1/16/2009 7:59:04 PM(UTC)
