Earl w
#1 Posted : Sunday, August 15, 2010 9:08:11 AM(UTC)
Earl w
my G E electric clothes dryer will work when you turn the start switch but whe you let go it stops. any body know whats wrong?:)
#2 Posted : Monday, August 16, 2010 2:04:50 AM(UTC)
On most units there are 2 centrifugal switches on the motor.
They close when the motor gets close to operating speed.
One connects in the heater so that it does not heat up without air flow.
The other provides a circuit path to the motor so the start switch can be released.
Could be that switch is toast or is not being activated.
If you do not have heat when holding the start switch closed then odds are the motor switch is not being activated. This could be just dust etc. jamming the centrifugal mechanism on the motor or the mechanism is broken.
whirlpool dryer starts then stops in twp seconds (Dryer Repair)
by ptk100 5/6/2014 6:20:37 PM(UTC)
Dryer Starts then Stops (Dryer Repair)
by tbakker 10/8/2012 4:44:31 PM(UTC)
Dryer starts then stops when drum is manually moved (Dryer Repair)
by WinePoet 2/19/2012 11:58:57 AM(UTC)
Kenmore HE3 Dryer starts then stops (Dryer Repair)
by nowhere 1/13/2012 8:32:59 PM(UTC)
dryer starts then stops (Dryer Repair)
by John Herrera 11/22/2010 8:54:47 AM(UTC)
by skinners 10/16/2010 7:39:23 AM(UTC)
by drewmar 9/30/2009 1:37:00 PM(UTC)
dryer starts then stops and makes noises (Dryer Repair)
by karenmpls 1/16/2009 7:59:04 PM(UTC)
