Hi, this Maytag washer started making a growling noise when spinning and agitating and now stops moving under a load. I can hold slight hand pressure on the drum and stop it from turning, the shaft going into the transmission does turn. Is this a bad transmission? Worth fixing?
Groups: APP Team
