Chris1320
#1 Posted : Monday, January 28, 2013 8:33:45 PM(UTC)
Chris1320
this Maytag washer started making a growling noise when spinning and agitating and now stops moving under a load. I can hold slight hand pressure on the drum and stop it from turning, the shaft going into the transmission does turn. Is this a bad transmission? Worth fixing?
Simon / APP Team
#2 Posted : Tuesday, January 29, 2013 11:02:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It does sounds like the bad transmission
Part number: 35-6615
This job may take 2-3 hrs if you are a DIY and it's a bit pricey.
It's your call.
Here are the breakdown diagrams and 06-Transmission parts for Maytag MAV208DAWW - AppliancePartsPros.com
Simon.
