djkotara
#1 Posted : 12 years ago
djkotara
My side by side has a problem. I started to smell burning from in freezer. Then it stopped cooling. It sounds fine, but quit cooling. So I checked behind the back panel in the freezer and found that the defrost heater had blown up about 8 inches down on the right side. Is that my whole problem and I just need to get a new defrost heater? Or is there something else going on that caused that to happen?
#2 Posted : 12 years ago
A model number may help others help you.
I cannot say if the heater is your only problem.
What did the evaporator (freezer) coils look like when you looked at them.
If they were heavily iced/frosted over then it could be that the heater is the only problem.
SAMSUNG RF26J7500SR/AA - defrost heater testing (Refrigerator & Freezer Repair)
by curious99 2 years ago
defrost heater not working but testing fine on multimeter (Refrigerator & Freezer Repair)
by doland 2 years ago
Samsung Bottom Freezer Refrigerator Defrost Heater Replacement Part Help (Refrigerator & Freezer Repair)
by treefort 2 years ago
Replacing the defrost heater, one bulb or two bulb heater? (Refrigerator & Freezer Repair)
by emilclintoc 3 years ago
Defrost heater for very old Sears Coldspot 106.7627410 (Refrigerator & Freezer Repair)
by kboyette 3 years ago
No power to defrost heater during forced defrost mode (Kenmore Elite) (Refrigerator & Freezer Repair)
by skssf 4 years ago
How To Cycle Defrost Heater On Freezer (Refrigerator & Freezer Repair)
by DavyP49 5 years ago
Defrost heater question (Refrigerator & Freezer Repair)
by phildonnia 6 years ago
Defrost Heater always On. (Refrigerator & Freezer Repair)
by peterwapel 7 years ago
Defrost Heater (Refrigerator & Freezer Repair)
by mokalan 7 years ago
Defrost heater burning evaporator cover side gasket (Refrigerator & Freezer Repair)
by bahoefs59 7 years ago
Correct Readings for Thermostat/Defrost Heater (Refrigerator & Freezer Repair)
by willjohnston 8 years ago
Problem with Defrost Heater (Refrigerator & Freezer Repair)
by edkress 8 years ago
Defrost heater and thermostat (Refrigerator & Freezer Repair)
by Servicer123456 8 years ago
Defrost heater stays on during cooling cycle (Refrigerator & Freezer Repair)
by ragpicker 10 years ago
