I have a Whirlpool WGD5800SWO dryer that we have had for a few years now and it now will not start.
It has no power at all.
I have check these items all seem OK.
Push to Start Relay reads zero ohms. Door switch reads zero ohms Thermal fuse reads zero ohms Operating thermostat reads zero ohms (thermostat heater reads 4.8K ohms) Thermal cutoff read zero ohms Hi limit thermostat reads zero ohms Applied 110 V to motor and it spins freely Door light works.
Not sure what check on the timer swich to verified that it working correctly. I do hear the swich time running but no power.
Please let me know what else to try.
Thanks Joe
It seems that switch four on timer switch should power up dryer. I think I should jumper T - W to power dryer. On back side of connection I get 120 V across T -W with timer going and when I push the push to start switch.
I think its the timer switch but not positive. It could still be the motor?
Joe
Timer Switch Part number is 3406725. On the plug side of Timer switch I get 120 volts across T -W when I engage the timer switch and engage the push to start switch. Not sure is the Timer Switch 4 is engaging. ANy other suggestions?
Thanks Joe
Well it ended up being the timer switch....T - W was open.....Never did get a response for the forum....Thanks Anyway
