The convection fan has always been intermittent and even when it worked, it spun so slow, that I doubt it had any affect. How fast should it spin? What would cause it to spin slow and be intermittent? Thanks!
Groups: APP Team
Hi. Check if the fan blade is rotating absolutely free and do not stuck on any surrounding objects.If the shaft turns with some resistance - replace the motor Part number: 74011174
