lestex5
#1 Posted : Saturday, January 12, 2013 4:45:37 PM(UTC)
lestex5
my Frigidaire oven is not heating up I have tested every thing and used and ohm meter and all test good but 1 thing the little red light on the front I tested this lamp with my meter and its not ohming at all this is a Frigidaire oven classic series ... could this be the reason my oven is not heating up??????????? please HELP Its and indicator light that says element light on the front it is 125v
lestex5
#2 Posted : Saturday, January 12, 2013 4:46:37 PM(UTC)
lestex5
Read more: http://forum.appliancepartspros...-oven.html#ixzz2HoeS6odS
http://forum.appliancepartspros.com
#3 Posted : Sunday, January 13, 2013 4:49:42 AM(UTC)
Parts for Frigidaire FEF366CCD Range - AppliancePartsPros.com
Here is your wiring diagram.
http://manuals.frigidaire.com/p...pringfield/316255347.pdf
I think the red light you are referring to is for the stove top (hot surface), not the oven.
I am assuming that the stove top elements work OK.
Does the oven stay in pre-heat or does it show that it is ready.
if it stays in preheat then odds are that the control board is toast.
lestex5
#4 Posted : Sunday, January 13, 2013 11:56:47 AM(UTC)
lestex5
the oven stays in pre heat and never goes to ready
#5 Posted : Sunday, January 13, 2013 11:25:08 PM(UTC)
Sounds like the control board is toast.
I would check the oven sensor if you have not done it, just to be sure it is OK.
Below is a good link, look at 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
power outage has my oven unable to turn on to reset (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 10:17:47 PM(UTC)
I'm New & Did Something Really Dumb With My Oven, Suggestions? (Oven Repair (including Ranges and Cooktops))
by Udon 4/24/2021 10:09:11 PM(UTC)
My Oven doesn't start (Oven Repair (including Ranges and Cooktops))
by davidgonzalezc 7/24/2015 5:41:21 PM(UTC)
My Husband broke my oven! (Oven Repair (including Ranges and Cooktops))
by Wanda Elaine 1/18/2015 1:10:38 PM(UTC)
F1 and E5 code on my oven (Oven Repair (including Ranges and Cooktops))
by kclan4 12/1/2013 7:07:23 AM(UTC)
My oven elements will not work (Oven Repair (including Ranges and Cooktops))
by Billman 9/8/2013 2:11:25 PM(UTC)
I accidentally pulled off my oven door... (Oven Repair (including Ranges and Cooktops))
by bleumoose 6/25/2013 11:22:11 AM(UTC)
IS this the right ERC for my Oven (Oven Repair (including Ranges and Cooktops))
by o2fill 5/8/2013 11:47:39 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Self cleaning killed my oven. Where is thermal fuse at? (Oven Repair (including Ranges and Cooktops))
by Javawagen 11/8/2012 2:44:46 PM(UTC)
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 9/24/2012 5:50:52 PM(UTC)
Is my oven dead? (Oven Repair (including Ranges and Cooktops))
by Gator81 9/9/2012 5:53:48 AM(UTC)
Shouldn't have cleaned my oven! (Oven Repair (including Ranges and Cooktops))
by tlhutton 6/25/2012 3:05:51 PM(UTC)
Problem with my oven door not closing (Oven Repair (including Ranges and Cooktops))
by REV1842000 6/7/2012 4:52:28 AM(UTC)
why my oven does not turn on? (Oven Repair (including Ranges and Cooktops))
by elbebe2525 4/16/2012 2:14:42 PM(UTC)
