| » My Oven |
Model Number: fef366ccd Brand: Frigidaire Age: 1 - 5 years
my Frigidaire oven is not heating up I have tested every thing and used and ohm meter and all test good but 1 thing the little red light on the front I tested this lamp with my meter and its not ohming at all this is a Frigidaire oven classic series ... could this be the reason my oven is not heating up??????????? please HELP Its and indicator light that says element light on the front it is 125v
Read more: My Oven http://forum.appliancepartspros.com |
Parts for Frigidaire FEF366CCD Range - AppliancePartsPros.com Here is your wiring diagram. http://manuals.frigidaire.com/prodin.../316255347.pdf I think the red light you are referring to is for the stove top (hot surface), not the oven. I am assuming that the stove top elements work OK. Does the oven stay in pre-heat or does it show that it is ready. if it stays in preheat then odds are that the control board is toast.
__________________
Sounds like the control board is toast.
I would check the oven sensor if you have not done it, just to be sure it is OK. Below is a good link, look at 7, 8, 20 and 21. http://www.applianceaid.com/electric...air-topics.php
__________________
| Display Modes | |
