my Frigidaire oven is not heating up I have tested every thing and used and ohm meter and all test good but 1 thing the little red light on the front I tested this lamp with my meter and its not ohming at all this is a Frigidaire oven classic series ... could this be the reason my oven is not heating up??????????? please HELP Its and indicator light that says element light on the front it is 125v
my Frigidaire oven is not heating up I have tested every thing and used and ohm meter and all test good but 1 thing the little red light on the front I tested this lamp with my meter and its not ohming at all this is a Frigidaire oven classic series ... could this be the reason my oven is not heating up??????????? please HELP Its and indicator light that says element light on the front it is 125v Read more: http://forum.appliancepartspros...-oven.html#ixzz2HoeS6odS http://forum.appliancepartspros.com
THIS FORUM IS DEAD!!!!!!! |
the oven stays in pre heat and never goes to ready
