Barry Lassiter
#1 Posted : Saturday, January 5, 2013 5:43:24 PM(UTC)
Barry Lassiter
I have a Kitchenaid Side by Side Refrigerator, Model KSRS25IHSS02. We were out running errands and the ice maker apparently went haywire. When we got home, ice and water all in the freezer and all over the kitchen floor. Turned the ice maker off and cleaned everything up and turned the ice maker back on and nothing. Would not fill with water or anything. When I open the freezer door, the Ice Maker Control red sensor light is blinking twice rapidly with about a 1 second interval before it blinks twice again. When I press in the emitter flapper door (On the left side) to unblock the optics beam, it does the same thing. No changeā€¦.blink twice, pause for a second and blinks twice again. From what I have read in previous posts, sounds like the optics are bad. Would that also have caused all the flooding? Any help is greatly appreciated.
Thank you,
Barry
#2 Posted : Sunday, January 6, 2013 2:29:22 AM(UTC)
Seems like bad optics. The flooding may be due to a bad water solenoid in the back, or a stalled icemake stuck in fill mode.
Barry Lassiter
#3 Posted : Saturday, March 30, 2013 7:55:23 AM(UTC)
Barry Lassiter
Hi again....finally got around to replacing the optics. Replaced them yesterday. When you open the door optics light blinks twice with a 1 second delay then does so again. When I push in the flapper door, light stays lit continuously. From what I read that means optics are working. However, the ice maker has not filled with water and is not making ice. Any advice on what I should check next? THANKS!!
#4 Posted : Saturday, March 30, 2013 12:57:17 PM(UTC)
Pull off the icemaker front and place a voltmeter meter in test points N and L and at the same time close the flapper and door switches.LED should go invisible and You should get 115 volts in a few minutes. If not, you have bad wiring to the optics, rather common. If ok, replace the icemaker.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
