roxytack
#1 Posted : Wednesday, January 2, 2013 4:04:26 PM(UTC)
roxytack
I can't figure out how to get the knob off the timer. The back of the timer had two thin lock pins on either side of the timer shaft and i removed them. I cant' pull or rotate the knob to get it off. Help!
#2 Posted : Thursday, January 3, 2013 2:00:28 PM(UTC)
Hello,
You have to remove the cap off the timer knob to release the knob from the timer. The cap unsnaps off the knob.
roxytack
#3 Posted : Thursday, January 3, 2013 3:39:27 PM(UTC)
roxytack
Thanks, it popped right off. I couldn't break into the timer because The plastic was heat sealed at critical points. So I gave up and ordered another one. Thanks
