roxytack
#1 Posted : 12 years ago
roxytack
I can't figure out how to get the knob off the timer. The back of the timer had two thin lock pins on either side of the timer shaft and i removed them. I cant' pull or rotate the knob to get it off. Help!
#2 Posted : 12 years ago
Hello,
You have to remove the cap off the timer knob to release the knob from the timer. The cap unsnaps off the knob.
roxytack
#3 Posted : 12 years ago
roxytack
Thanks, it popped right off. I couldn't break into the timer because The plastic was heat sealed at critical points. So I gave up and ordered another one. Thanks
