lriffe
#1 Posted : Saturday, December 22, 2012 12:01:53 PM(UTC)
lriffe
Evaporator fan was periodically getting ice encrusted and had to remove ice because of the noise. Last time as I was preparing to reattach the panel, the fan arced and stopped working. I replaced the fan, no luck. I then replaced the defrost thermostat, still no luck. Any suggestions before I call a repairman?
#2 Posted : Sunday, December 23, 2012 12:30:41 AM(UTC)
If the motor wire shorted to the panel, you may have blown the motor 5303918549 Remove it and plug it into the wall outlet, if it fails to run, replace it.
lriffe
#3 Posted : Sunday, December 23, 2012 5:37:51 AM(UTC)
lriffe
I did replace the fan motor, and it still doesn't work. Schematic shows fan motor and defrost thermostat share a common wire, along with the defrost heater. I've also replaced the defrost thermostat. Still doesn't work.
#4 Posted : Sunday, December 23, 2012 6:25:23 AM(UTC)
The evaporator fan motor gets it's power from the adc kit 5303918476, but check your schematic. Not usual, but the door switch might also be in series with the motor.
U-Line Evaporator Fan Not working (Refrigerator & Freezer Repair)
by roscoej 10/5/2021 7:24:11 PM(UTC)
evaporator fan not working, help!! (Refrigerator & Freezer Repair)
by MLF4 1/30/2016 3:33:38 PM(UTC)
evaporator fan not working (Refrigerator & Freezer Repair)
by rnjackson1 10/9/2015 1:04:39 PM(UTC)
Evaporator Fan Not Working (Refrigerator & Freezer Repair)
by dwgfelix 9/8/2015 8:36:01 AM(UTC)
Warm fridge, and evaporator fan not working (Refrigerator & Freezer Repair)
by livingstone 5/30/2013 2:51:37 AM(UTC)
Evaporator fan not working - microcomuter issue? (Refrigerator & Freezer Repair)
by trixkit 2/25/2013 11:37:04 AM(UTC)
Evaporator Fan Not Working Properly (Refrigerator & Freezer Repair)
by bpete 1/26/2011 6:36:48 PM(UTC)
by sdonatos 9/18/2010 3:55:02 AM(UTC)
evaporator fan not working GE ZISS48DCASS (Refrigerator & Freezer Repair)
by blkfin 8/31/2010 5:34:44 PM(UTC)
Evaporator Fan not working? (Refrigerator & Freezer Repair)
by lq89 5/17/2009 10:25:03 AM(UTC)
Freezer cold, evaporator fan not working, frost build up in freezer (Refrigerator & Freezer Repair)
by heretolearn2 5/23/2008 5:56:15 AM(UTC)
Evaporator fan not working (Refrigerator & Freezer Repair)
by tony51 10/21/2007 10:17:42 AM(UTC)
