It appears that the motor in my dryer has died. Even if I disconnect it and try to power it, it only hums. I tried to remove the motor but I do not see how to get the blower fan disconnected. I cannot find a manual so Im not even certain the correct procedure to remove the drum. I can get it opened up. but Im not sure what to remove to pull the drum so I can more easily get to the motor.
any help will be greatly appreciated.
THIS FORUM IS DEAD!!!!!!! |
