Discuss
Replacing Kenmore dryer motor
 in
Dryer Repair
I am replacing the old motor with Part number: AP3094245 (279827). The instructions call for rearranging some of the wiring.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replacing Kenmore dryer motor
  #1 (permalink)
Old 08-20-2009, 09:31 AM
Junior Member
marksan is on a distinguished road
Exclamation Replacing Kenmore dryer motor
Model Number: 11076702693   Brand: -brand-   Age: More than 10 years
(279827). The instructions call for rearranging some of the wiring. The harness colors do not match those in the instructions. However, the the wire plug looks the same on the old and new. The configuration also looks the same.Can I just plug the old plug into the new motor?
Related Models
Kenmore 11076702693 GAS DRYER
Kenmore 11076712690 GAS DRYER
Kenmore 11076712691 GAS DRYER
Kenmore 11076712692 GAS DRYER
Kenmore 11076712693 Residential Dryer
Kenmore 11076712694 GAS DRYER
Kenmore 11076712695 GAS DRYER
Kenmore 11076722690 ELECTRIC DRYER
Kenmore 11076722691 GAS DRYER
Kenmore 11076722692 GAS DRYER
Kenmore 11076722693 GAS DRYER
Kenmore 11076722694 GAS DRYER
Kenmore 11076722695 GAS DRYER
Kenmore 11076732500 RESIDENTIAL DRYER
Kenmore 11076732501 RESIDENTIAL DRYER
Kenmore 11076742500 RESIDENTIAL DRYER
Kenmore 11076742501 RESIDENTIAL DRYER
Kenmore 11076752500 DRYER
Kenmore 11076752501 RESIDENTIAL DRYER
Kenmore 11076774100 KENMORE ELECTRIC DRYER
Kenmore 11076774200 KENMORE ELECTRIC DRYER
Kenmore 11076774400 KENMORE ELECTRIC DRYER
Kenmore 11076774600 KENMORE ELECTRIC DRYER
Kenmore 11076784100 KENMORE ELECTRIC DRYER
Kenmore 11076784200 KENMORE ELECTRIC DRYER
Kenmore 11076784400 KENMORE ELECTRIC DRYER
Kenmore 11076784600 KENMORE ELECTRIC DRYER
Kenmore 11076785100 KENMORE ELECTRIC DRYER
Kenmore 11076785200 KENMORE ELECTRIC DRYER
Kenmore 11076785400 KENMORE ELECTRIC DRYER
Kenmore 11076785600 KENMORE ELECTRIC DRYER
Kenmore 11076801690 ELECTRIC DRYER
Kenmore 11076801691 GAS DRYER
Kenmore 11076801692 GAS DRYER
Kenmore 11076801693 GAS DRYER
Kenmore 11076801694 GAS DRYER
Kenmore 11076801695 GAS DRYER
Kenmore 11076808690 GAS DRYER
Kenmore 11076808691 GAS DRYER
Kenmore 11076808692 GAS DRYER
Kenmore 11076808693 GAS DRYER
Kenmore 11076808694 GAS DRYER
Kenmore 11076808695 GAS DRYER
Kenmore 11076812690 ELECTRIC DRYER
Kenmore 11076812691 GAS DRYER
Kenmore 11076812692 GAS DRYER
Kenmore 11076812693 GAS DRYER
Kenmore 11076812694 GAS DRYER
Kenmore 11076812695 GAS DRYER
Kenmore 11076814690 GAS DRYER
Kenmore 11076814691 GAS DRYER
Kenmore 11076814692 GAS DRYER
Kenmore 11076814693 GAS DRYER
Kenmore 11076814694 GAS DRYER
Kenmore 11076814695 GAS DRYER
Kenmore 11076822690 SUPER CAPACITY PLUS CLOTHES DRYER
Kenmore 11076822691 GAS DRYER
Kenmore 11076822692 GAS DRYER
Kenmore 11076822693 Residential Dryer
Kenmore 11076822694 GAS DRYER
Kenmore 11076822695 GAS DRYER
Kenmore 11076824690 GAS DRYER
Kenmore 11076824691 GAS DRYER
Kenmore 11076824692 GAS DRYER
Kenmore 11076824693 GAS DRYER
Kenmore 11076824694 GAS DRYER
Kenmore 11076824695 GAS DRYER
Kenmore 11076832500 RESIDENTIAL DRYER
Kenmore 11076832501 RESIDENTIAL DRYER
Kenmore 11076842500 DRYER
Kenmore 11076842501 RESIDENTIAL DRYER
Kenmore 11076852690 ELECTRIC DRYER
Kenmore 11076852691 GAS DRYER
Kenmore 11076852692 GAS DRYER
Kenmore 11076852693 Residential Dryer
Kenmore 11076852694 GAS DRYER
Kenmore 11076852695 GAS DRYER
Kenmore 11076854690 GAS DRYER
Kenmore 11076854691 GAS DRYER
Kenmore 11076854692 GAS DRYER
Kenmore 11076854693 GAS DRYER
Kenmore 11076854694 GAS DRYER
Kenmore 11076854695 GAS DRYER
Kenmore 11076860100 KENMORE ELECTRIC DRYER
Kenmore 11076860200 KENMORE ELECTRIC DRYER
Kenmore 11076860400 KENMORE ELECTRIC DRYER
Kenmore 11076860600 KENMORE ELECTRIC DRYER
Kenmore 11076860800 KENMORE ELECTRIC DRYER
Kenmore 11076862500 RESIDENTIAL DRYER
Kenmore 11076862501 RESIDENTIAL DRYER
Kenmore 11076864501 RESIDENTIAL DRYER
Kenmore 11076870100 KENMORE ELECTRIC DRYER
Kenmore 11076870200 KENMORE ELECTRIC DRYER
Kenmore 11076870400 KENMORE ELECTRIC DRYER
Kenmore 11076870600 KENMORE ELECTRIC DRYER
Kenmore 11076870800 KENMORE ELECTRIC DRYER
Kenmore 11076872500 DRYER
Kenmore 11076872501 RESIDENTIAL DRYER
Kenmore 11076873100 KENMORE ELECTRIC DRYER
Kenmore 11076873200 KENMORE ELECTRIC DRYER
Kenmore 11076873400 KENMORE ELECTRIC DRYER
Kenmore 11076873600 KENMORE ELECTRIC DRYER
Kenmore 11076873800 KENMORE ELECTRIC DRYER
Kenmore 11076875100 KENMORE ELECTRIC DRYER
Kenmore 11076875200 KENMORE ELECTRIC DRYER
Kenmore 11076875400 KENMORE ELECTRIC DRYER
Kenmore 11076875600 KENMORE ELECTRIC DRYER
Kenmore 11076876100 KENMORE ELECTRIC DRYER
Kenmore 11076876200 KENMORE ELECTRIC DRYER
Kenmore 11076876400 KENMORE ELECTRIC DRYER
Kenmore 11076876600 KENMORE ELECTRIC DRYER
Kenmore 11076876800 KENMORE ELECTRIC DRYER
Kenmore 11076877100 KENMORE ELECTRIC DRYER
Kenmore 11076877200 KENMORE ELECTRIC DRYER
Kenmore 11076877400 KENMORE ELECTRIC DRYER
Kenmore 11076877600 KENMORE ELECTRIC DRYER
Kenmore 11076877800 KENMORE ELECTRIC DRYER
Kenmore 11076880100 KENMORE ELECTRIC DRYER
Kenmore 11076880200 KENMORE ELECTRIC DRYER
Kenmore 11076880400 KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 08-22-2009, 11:40 AM
Junior Member
Espritman is on a distinguished road
Default
Marksan, I have no answer for you but a question. Our Kenmore dryer models are similarly aged. No one has responded to my post about removing the motor. Please respond if you can assist. Here's my post:
I must replace the motor that drives the drum. I have removed the front panel, the drum, belt and the 2 clips holding the motor to its bracket. I have also removed the rear panel of the dryer but can't figure out how to get access to the rear of the motor in order to remove it and install the fan and/or pulley to the new motor? I'll send pictures offline if that will help. Thank you!
Espritman
an you help?
  #3 (permalink)
Old 08-22-2009, 06:15 PM
Junior Member
Default
Espritman
an you help?
I was able to complete my installation successfully. At the rear of the motor is a square nut that is attached to the fan. It's a little hard to see. You will need to use an open-ended or crescent wrench to keep it from moving while you turn the motor shaft from the front CLOCKWISE. Grip the front of the shaft at the flat area between the pulley and the motor. It can be hard and a little awkward to break the nut loose, so don't bang any knuckles. You then do the reverse to re-install the motor.
Hope this helps.
  #4 (permalink)
Old 08-22-2009, 07:02 PM
Junior Member
Default
You bet it it does! We were confounded. Thank you!
Your new motor # is identical to mine. Apparently, it is the replacement for many older machine's motors.
Let's see if I understand you correctly:
From the rear of the dryer with the panel removed, you were able to lie on the floor and reach into the lint/heat exhaust tube horizontally (and blind) at the very bottom of the machine with a wrench that you used to remove the square(?) nut on the end of the motor (fan) shaft while (someone else) turning the pulley clockwise on the other end of the motor? I was able to reach in and feel the fan but I don't think I could see it.
More clarifying:
Does your machine have a rectangular vertical gray metal tube that runs the height of the unit up the left (from the rear) side to the lint filter?
I have a feeling that this is going to be the solution to a confounding problem. I'll find out early in September when I 'visit' the machine again.
Right now, it's in pieces. The 'classic' method of clothes drying is being used.
Sincere thanks.
Bob
  #5 (permalink)
Old 08-23-2009, 06:23 AM
Junior Member
Default
More clarifying:
Sincere thanks.
Bob
I accessed the nut from inside the cabinet and behind the motor. If someone holds the fan steady from the back, so much the better. Pushing the fan as far forward as possible may help you to see the nut inside.
  #6 (permalink)
Old 09-29-2009, 11:57 AM
Junior Member
Russell2004 is on a distinguished road
Default
Bob and Marksan,
Do you have any suggestions as to where I can find step by step instructions on replacing the motor? We are replacing the same part (Part number: 279827
Part number: 279827
) and are trying to save money by doing it ourselves. Any resources you found helpful would be appreciated!! I will also be referring to this thread to remove the blower.
Thanks!
PS. The dryer broke in May and we've also been using the "classic" method this summer! Now it's time to fix it!!
  #7 (permalink)
Old 09-29-2009, 12:39 PM
Junior Member
Default
Quote:
Originally Posted by Russell2004 View Post
Bob and Marksan,
Do you have any suggestions as to where I can find step by step instructions on replacing the motor? We are replacing the same part (279827) and are trying to save money by doing it ourselves. Any resources you found helpful would be appreciated!! I will also be referring to this thread to remove the blower.
Thanks!
Sorry, no help from me. We tried everything we could think of, then sent the $100 motor back to Sears and bought a new one for $300 delivered with the (very) old one removed. Ours had to be different from Marksan's.
  #8 (permalink)
Old 09-29-2009, 04:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bob and Marksan,
Thanks!
What is the complete model number of the dryer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing heating element in Kenmore stacked dryer LLesniak Dryer Repair 1 02-04-2010 06:14 PM
Kenmore dryer - bad motor? stevehtm Dryer Repair 3 10-21-2009 06:41 AM
Kenmore elec dryer motor timclayton Dryer Repair 1 10-14-2009 11:33 AM
Replacing Whirpool Clothes Dryer Motor JACKDADDY Dryer Repair 3 08-24-2009 05:12 PM
Kenmore Dryer Motor Replacement NikE6229 Dryer Repair 1 08-11-2008 03:01 AM
