gohrnz
#1 Posted : Sunday, September 27, 2009 12:22:59 PM(UTC)
gohrnz
It appears that the motor in my dryer has died. Even if I disconnect it and try to power it, it only hums. I tried to remove the motor but I do not see how to get the blower fan disconnected. I cannot find a manual so Im not even certain the correct procedure to remove the drum. I can get it opened up. but Im not sure what to remove to pull the drum so I can more easily get to the motor.
any help will be greatly appreciated.
gohrnz
#2 Posted : Monday, September 28, 2009 7:51:17 PM(UTC)
gohrnz
bump to first page
#3 Posted : Tuesday, September 29, 2009 3:23:51 AM(UTC)
Here is a manual.
http://frigidaireservicetips.co...rGoodandBetterModels.pdf
Am not sure if it covers your model but odds are high that the things you want to do will be the same procedures as in the manual.
Russell2004
#4 Posted : Tuesday, September 29, 2009 11:15:12 AM(UTC)
Russell2004
http://forum.appliancepartspros...kenmore-dryer-motor.html
Check out this thread. They were discussing this very issue. I don't know if their model is the same as yours, but it may be helpful! Good luck!
