hollowayv
#1 Posted : Tuesday, December 4, 2012 8:09:39 AM(UTC)
hollowayv
hi trying to find help with a lg washer model wm2277hw it will not drain gives oe code checked all drains and both pumps all are good even removed the pumps cleaned and tested them on the bench both run great. re-installed ran through 1 cycle ok then again with the oe code. called repair guy he came out same thing with one exception when he tested the leads to the drain pump they are only register at 94-97volts so i checked the outlet it is fine 120v. so my question is do i replace the mother board? is it possibly sending a wrong signal to the drain pump? or would i go with replacing the the drain pump even though it ran great independently?
Simon / APP Team
#2 Posted : Tuesday, December 4, 2012 11:41:44 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check how far is the drain hose goes inside the drain pipe.
Check the impeller inside the pump.
Check the voltage drop at the outlet when the washer is set to drain.
Try to plug it into the different outlet.
Check the plugs at the main PCB and if that's OK - replace the main PCB Part number: 6871ER1078T
Remember that you can return any unused parts back to APP even if they been installed.
Here are the breakdown diagrams and parts for LG WM2277HW - AppliancePartsPros.com
Simon.
saxmandon
#3 Posted : Monday, February 18, 2013 3:30:33 PM(UTC)
saxmandon
I have same issue, how did you fix it?
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
lg wm2277hs drain problem (Washer Repair)
by Spiderman70 7/30/2020 6:37:35 AM(UTC)
kitchen aid drain problem not all the time (Dishwasher Repair)
by tom setre 1/22/2019 8:34:59 AM(UTC)
Drain problem (Dishwasher Repair)
by CATAXMAN 5/22/2015 7:42:29 AM(UTC)
Neptune MAH7500 - drain problem (Washer Repair)
by matopruth 3/8/2014 8:35:04 AM(UTC)
Maytag Neptune MAH5500BWW drain problems (Washer Repair)
by Tyork1 11/29/2013 6:02:24 PM(UTC)
neutral drain problem (Washer Repair)
by Tim2020 8/16/2013 9:47:57 PM(UTC)
Washing machine drain problem (Washer Repair)
by jon_e 1/5/2013 11:30:20 AM(UTC)
Fridigaire front loader drain problems (Washer Repair)
by jesse.rizzo 11/11/2012 10:52:28 AM(UTC)
Maytag Neptune Drain Problem (Washer Repair)
by dhornman 8/22/2012 9:04:48 AM(UTC)
Dishwasher drain problem (Dishwasher Repair)
by hunterman 11/14/2011 7:56:54 AM(UTC)
by youngstown2 11/12/2011 7:11:48 AM(UTC)
spin and drain problem calypso (Washer Repair)
by jim806 6/27/2011 2:25:50 PM(UTC)
Intermittent fill/drain problem (Dishwasher Repair)
by nele 4/22/2011 5:59:37 AM(UTC)
by Tom Wardynski 3/7/2011 3:25:54 PM(UTC)
