which ever cycle i select the door locks then a few seconds later the door unlocks. The machine has a test mode where you can run the machine through each cycle and every cycle passed ok. do i need to replace the control board?
Originally Posted by: pilotincmd which ever cycle i select the door locks then a few seconds later the door unlocks. The machine has a test mode where you can run the machine through each cycle and every cycle passed ok. do i need to replace the control board? Did it show any error codes? If it did not then very likely the control board is bad. - The control board Part number: WH12X10468
