Bob Lewis
#1 Posted : Thursday, November 29, 2012 10:03:32 AM(UTC)
Bob Lewis
Oven over heats by 50 degrees, even after installing a new long oven sensor.
Any ideas?:confused:
Simon / APP Team
#2 Posted : Thursday, November 29, 2012 1:02:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the oven sensor's resistance at the control board disconnect plug (about 1100 ohm at room temp.)
If it is within the range - then most likely it's bad control board. If not - check the sensor's wire harness and plug at the back of the oven.
Simon.
Oven Over Heating (Oven Repair (including Ranges and Cooktops))
by LeesaBennett 5/8/2013 11:43:54 AM(UTC)
Oven over heating and locking door (Oven Repair (including Ranges and Cooktops))
by mfender 1/11/2013 9:47:23 AM(UTC)
oven over heating (Oven Repair (including Ranges and Cooktops))
by don_chan 1/5/2013 6:56:42 PM(UTC)
by greghzl 4/26/2011 1:10:33 PM(UTC)
Oven over heating (Oven Repair (including Ranges and Cooktops))
by pigg74 2/6/2008 6:17:14 PM(UTC)
