I turned the oven on to bake (350) within a few minutes it locked the door and started heating excessively. It took repeated attempts to turn off at panel. I repeated what I had done to be sure I had not accidentally hit the clean button. There error repeated. There was an error code displayed which unfortunately I did not take note of. Thank you for any assistance.
Groups: APP Team
Hi. Based on the information you provided the problem is within the control board which should be replaced Part number: 8302994
