Oven over heats by 50 degrees, even after installing a new long oven sensor. Any ideas?:confused:
Groups: APP Team
Hi.
Check the oven sensor's resistance at the control board disconnect plug (about 1100 ohm at room temp.) If it is within the range - then most likely it's bad control board. If not - check the sensor's wire harness and plug at the back of the oven.
Simon.
