AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer making screeching sound [video attached]
My dryer has been making a loud screeching sound for about a week which has gotten progressively worse. I took apart the dryer and the sound looks to be coming from the blower or the motor. This is my first time working on a dryer so any help pinpointing the problem would be appreciated. I've uploaded a video to youtube in case it's of help: Maytag dryer - screeching sound - YouTubeIs there anything else I can do to narrow down what's causing the sound? Or is it something obvious that I'm not aware of?
Most likely the problem is a bad blower wheel due to a worn out central hole. You will need a special pliers to remove the retaining ring (#12 at the diagram). - The blower wheel Part number: 31001317
Dryer Repair
