lath19
#1 Posted : Sunday, November 25, 2012 2:47:14 PM(UTC)
lath19
My dryer has been making a loud screeching sound for about a week which has gotten progressively worse. I took apart the dryer and the sound looks to be coming from the blower or the motor. This is my first time working on a dryer so any help pinpointing the problem would be appreciated. I've uploaded a video to youtube in case it's of help:
Maytag dryer - screeching sound - YouTube
Is there anything else I can do to narrow down what's causing the sound? Or is it something obvious that I'm not aware of?
#2 Posted : Monday, November 26, 2012 2:54:19 PM(UTC)
Most likely the problem is a bad blower wheel due to a worn out central hole. You will need a special pliers to remove the retaining ring (#12 at the diagram).
- The blower wheel Part number: 31001317
- The snap-ring pliers Part number: 73236
Part number: 73236
Here are the breakdown diagrams and Parts for Maytag PYG2300AWW Dryer - AppliancePartsPros.com
