youngbuck40
#1 Posted : Thursday, September 24, 2009 11:22:57 AM(UTC)
youngbuck40
spins in wash cycle pumps water all out and will not spin
does make a roar noise like the look underneath belt is spinning all 3 pulleys
washer has been sitting in storage for 3 months
sidfink43
#2 Posted : Friday, September 25, 2009 3:52:31 PM(UTC)
sidfink43
In many cases we can pinpoint the problem and suggest a solution. That is not the case here.
Your problem can be in the brakes, tranmission, thrust bearing and probably someother things. First make sure there is nothing jammed with the tub and basket and that the drain hoses are all clear.
Then use the service manual to see what you can find out.
http://www.servicematters.com/m...ibrary/docs/16026502.pdf
Good luck, with I could be more specific.
utjmac
#3 Posted : Tuesday, March 22, 2016 10:19:02 AM(UTC)
utjmac
I just found this thread from a search, and curious to the senior member who replied. Is there an ability to register for the service manual that you linked to, as it requires login information.
Thanks in advance for the response!
John
Maytag will not spin (Washer Repair)
by Wickel 6/16/2011 10:03:22 AM(UTC)
maytag will not spin agitate or pump (Washer Repair)
Belarus drembo 11/3/2007 11:27:04 AM(UTC)
