CaddyDaddy
#1 Posted : Tuesday, October 16, 2012 7:09:48 AM(UTC)
CaddyDaddy
I have a GE JBP35DM1CC Oven Stove. The single surface indicator light stays on even though all burner elements are cool to the touch and the surface controls are all off . All four elements work properly. I have a multi-meter to check for continuity. I have the schematics. Where do I place the leads on the surface control to check to see if the switch is bad?
CaddyDaddy
#2 Posted : Saturday, October 20, 2012 4:59:31 AM(UTC)
CaddyDaddy
Anyone out there have an answer to my question?
Hot Surface Indicator Light Stays On (Oven Repair (including Ranges and Cooktops))
by erindiane 1/11/2016 2:46:25 PM(UTC)
Surface Indicator Light stays ON/electric range (Oven Repair (including Ranges and Cooktops))
by KHIB 2/20/2012 4:10:09 PM(UTC)
surface indicator light stays on all the time (Oven Repair (including Ranges and Cooktops))
by nolesman98 3/15/2011 8:45:49 AM(UTC)
1 Burner doesn't work, and hot surface indicator light stays on (Oven Repair (including Ranges and Cooktops))
by ekleber 2/2/2011 2:32:00 PM(UTC)
