I have a GE JBP35DM1CC Oven Stove. The single surface indicator light stays on even though all burner elements are cool to the touch and the surface controls are all off . All four elements work properly. I have a multi-meter to check for continuity. I have the schematics. Where do I place the leads on the surface control to check to see if the switch is bad?
Anyone out there have an answer to my question?
