The "clean" light and the "light wash" light keep blinking. There is water in the bottom of the dishwasher that I can't drain. I tried turning power on/off but that didn't work. Any suggestions? Mary
Originally Posted by: marycf  The "clean" light and the "light wash" light keep blinking. There is water in the bottom of the dishwasher that I can't drain. I tried turning power on/off but that didn't work. Any suggestions? Mary The Maytag diagnostic tips manuals says: During Automatic Function Test, if a fault has been detected, the test will abort and 2 LED's will begin to flash. The CLEAN LED and: Keypad 2 LED ("light wash") - Motor - low current. I'd have someone check the voltage on the circuit your dishwasher is attached to make sure it is a at 120volts. Sounds like you have a brown-out voltage issue. Good Luck!
it appears your control board has failed
