marycf
#1 Posted : Monday, January 28, 2008 6:02:00 AM(UTC)
marycf
The "clean" light and the "light wash" light keep blinking. There is water in the bottom of the dishwasher that I can't drain. I tried turning power on/off but that didn't work. Any suggestions?
Mary
TexasCowboy
#2 Posted : Friday, May 2, 2008 4:27:46 PM(UTC)
TexasCowboy
Mary
The Maytag diagnostic tips manuals says:
During Automatic Function Test, if a fault has been detected, the test will abort and 2 LED's will begin to flash. The CLEAN LED and:
Keypad 2 LED ("light wash") - Motor - low current.
I'd have someone check the voltage on the circuit your dishwasher is attached to make sure it is a at 120volts. Sounds like you have a brown-out voltage issue. Good Luck!
misterfixall
#3 Posted : Friday, May 2, 2008 7:18:29 PM(UTC)
misterfixall
it appears your control board has failed
Whirlpool dishwasher lights flashing (Dishwasher Repair)
by Christie1974 3/31/2020 6:41:49 AM(UTC)
Whirlpool dishwasher lights flashing.... (Dishwasher Repair)
by MarkD12 2/24/2013 12:46:43 PM(UTC)
Dishwasher Lights Flashing (Dishwasher Repair)
by Aprilp 10/22/2012 7:14:13 AM(UTC)
Kitchenaid Dishwasher Lights Flashing (couldn't find answer in other posts) (Dishwasher Repair)
by dishwasherbroken 10/18/2010 10:55:41 AM(UTC)
Kitchen Aid Dishwasher lights flashing (Dishwasher Repair)
by sno-twister 10/26/2007 6:37:52 AM(UTC)
