Hey, guys. My Roper, Model RES7648EQ2 just stopped heating up. Should I just assume that it's the heating element, and can you point me in the direction of a good troubleshooting/walkthrough?
Thanks so much in advance.
Groups: APP Team
Hi. First you need to check if there is 240VAC to the dryer. If yes then unplug it,remove the back panel and using the multimeter check continuity of the: heating element, thermal cut off, high limit, cycling thermostat, thermal fuse. All this checks must be done with one wire off the part. Here are the breakdown diagrams and Bulkhead parts for Roper RES7648EQ2 - AppliancePartsPros.comPost the results. Simon.
