jjlittle.64
#1 Posted : Monday, August 27, 2012 10:29:37 PM(UTC)
jjlittle.64
The washing machine will not go into spin cycle. The motor tries to turn the drum, but it can't. The motor (or something) seems to be making a clicking noise. The belt is fine, the drum spins freely by hand. I have replaced the Motor Control Unit and it did not fix the problem. I thought a motor would either turn or not turn. Any ideas?
funday
#2 Posted : Tuesday, August 28, 2012 3:10:40 PM(UTC)
funday
Does the washer fill with water begin agatating and then pump the water to the drain so it can begin the spin cycle? If it fails to pump out water then the lid switch is bad. otherwise more info needed.
jjlittle.64
#3 Posted : Tuesday, August 28, 2012 8:01:41 PM(UTC)
jjlittle.64
Thanks for the reply. The pump out pump works fine. It pumps out the water when I restart it. I replaced the MCU, and it did not fix it. I replaced the pump today and it is now spinning just fine. The wife is much happier. Thanks again for the reply.
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Washing Machine not spinning (Washer Repair)
by Eigenbrod 6/10/2013 4:53:56 AM(UTC)
GE Washing Machine not spinning consistently (Washer Repair)
by Rjr19146 11/5/2012 6:15:45 AM(UTC)
WaShing Machine not spinning (Washer Repair)
by DennisBarrineau 9/1/2012 10:43:36 AM(UTC)
washing machine not spinning (Washer Repair)
by tessjones 6/12/2010 1:19:26 PM(UTC)
by jennyl11 11/20/2009 11:38:31 PM(UTC)
Frigidaire Top Loading Washing Machine not Spinning (Washer Repair)
by truett 6/27/2009 10:12:24 AM(UTC)
Kenmore washing machine not spinning (Washer Repair)
by Jim Bender 5/6/2009 7:48:20 AM(UTC)
