santana1
#1 Posted : Monday, August 20, 2012 9:37:06 PM(UTC)
santana1
when checking thermistor should it have continuity?
#2 Posted : Tuesday, August 21, 2012 1:56:10 AM(UTC)
Yes it should.
See Page 7 on the attached tech sheet.
Just saw your second post so have added some of it to this post.
[COLOR="Blue"] if so what number should i get on the digital readout, if i set the ohm meter on 200 it does not change if i put on 200K it reads 6.9[/COLOR]
As you can see from the resistance chart the resistance depends on temperature.
File Attachment(s):
63932100.pdf (291kb) downloaded 2 time(s).
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
Bad fresh food thermistor? (Refrigerator & Freezer Repair)
by barlav 10/1/2022 5:01:58 AM(UTC)
How do I access GE Evaporator Fan, coils, thermistor, etc (Refrigerator & Freezer Repair)
by Yari 8/4/2022 1:48:47 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Viking Thermistor Problem (Refrigerator & Freezer Repair)
by TDK-2020 10/21/2020 8:52:41 AM(UTC)
Maytag MRT311FFFZ00 thermistor chart & diagnostics mode (Refrigerator & Freezer Repair)
by scottaobe 2/1/2019 8:35:11 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
whirlpool GEX9868jt2. Was getting E1 error. replaced thermistor. Still getti (Dryer Repair)
by Garyatmaui 11/16/2017 12:19:47 PM(UTC)
how do i check the thermostat and thermistors (Refrigerator & Freezer Repair)
by ropeke 2/27/2017 2:25:42 PM(UTC)
E71 Outlet Control Thermistor (Dryer Repair)
by NaliKawi 2/2/2017 11:24:16 AM(UTC)
GE Hydrowave Top-Load... Thermistor Error... What Now? (Washer Repair)
by JoeyMac 8/12/2016 12:01:24 PM(UTC)
LG LSC27931ST Thermistor Part Number (Refrigerator & Freezer Repair)
by shackleford 11/12/2015 4:55:24 AM(UTC)
Duet E1 error after replacing thermistor (Dryer Repair)
by Steve8120 9/28/2014 6:48:28 PM(UTC)
Thermistor location(s) Refig and Freezer (Refrigerator & Freezer Repair)
by vincentjlawrence 9/15/2014 1:51:35 PM(UTC)
