skip
#1 Posted : Saturday, January 26, 2008 9:14:54 AM(UTC)
skip
I need to check the chopper blade assembly in my Kitchenaid KUDS01IJWHO but can not remove the protector/cover part PS392941. I've removed the torx screws and the top protector shield and can not get the protector covering the chopper assembly to budge. What am I doing wrong?
Thank you.
ripleys
#2 Posted : Saturday, January 26, 2008 11:44:12 AM(UTC)
ripleys
It's stuck on!!!
Sweet talk it a little and you may have to use a flat blade screwdriver to pry on it GENTLY to loosen it.
If the torx screws are out it should lt should lift off. Use a turkey baster to remove any existing water (makes it easier to see everything) and make sure your model doesn't have a plastic clip holding it on.
skip
#3 Posted : Saturday, January 26, 2008 11:56:31 AM(UTC)
skip
Thanks for replying. It sure is stuck - I've been prying - and not too gently either. Still no luck. I tried the turkey baster, but it's like trying to bail out a boat with holes - more water keeps coming in. I removed the screw on the left side of the cover - are there other screws on the cover itself?
ripleys
#4 Posted : Saturday, January 26, 2008 11:59:44 AM(UTC)
ripleys
I think there are two screws one is down behind the chopper cover under the water. That's why I suggested to get ALL the water out so you can see everything.
skip
#5 Posted : Saturday, January 26, 2008 12:19:10 PM(UTC)
skip
Success at last - I used a hairdryer and once the part warmed up it popped off.
#6 Posted : Sunday, January 27, 2008 3:06:33 AM(UTC)
If the chopper is clogged up, order a new chopper and check valve near the chopper and stuck in the pump base.
