barbariano298
#1 Posted : Friday, January 25, 2008 8:05:13 AM(UTC)
barbariano298
dishwasher doesn't pump out all of the water. bottom of tub has water left in it. pump has some pressure when dumping.
fyxer
#2 Posted : Friday, January 25, 2008 9:31:26 AM(UTC)
fyxer
First check the drain line where it connect to the sink, make sure it is not clogged there, also check if the pump is working, if both things are ok then the problem is the--piston & nut.
The piston & nut is a litttle plastic thing with a spring on it this is located on the inside of the dishwasher at the back this is how you get to it,
at the back of the dishwasher on the inside there is a strip of plastic with mesh on it this is held in place with four 1/4 inch screws use a 1/4 nut driver to remove them, lift up and remove the strip, under the strip you will see the piston & nut sometimes you can use your fingers to un screw it if not use a pliers to move it then use your fingers to un screw it, take it to your local parts store or order it from --appliance parts pro--.
GE Profile Dishwasher Hums when Off (Dishwasher Repair)
by Thom64 2/7/2022 7:19:40 PM(UTC)
GE profile dishwasher PDW9980N00SS starts then stops (Dishwasher Repair)
by cfcstl 12/15/2020 8:18:18 AM(UTC)
GE Profile Dishwasher QP 47 Can't move between different Wash programs (Dishwasher Repair)
by MTHall720 3/26/2020 11:32:29 AM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 4:33:33 PM(UTC)
GE profile dishwasher (Dishwasher Repair)
by barnee72 1/14/2016 5:47:55 PM(UTC)
GE Profile Dishwasher lights up, but will not start (Dishwasher Repair)
by cjsrinivas 12/21/2015 8:06:27 PM(UTC)
ge profile dishwasher - nut water inlet - repair or replace? (Dishwasher Repair)
by dsynadinos 3/1/2014 5:22:20 AM(UTC)
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 2/25/2014 5:52:10 AM(UTC)
GE Profile dishwasher GHDA696Pss doesnt drain completely (Dishwasher Repair)
by jdn9580 1/11/2014 10:15:13 AM(UTC)
ge profile dishwasher (Dishwasher Repair)
by rickcallaway 11/4/2013 8:17:53 AM(UTC)
GE Profile dishwasher motor fan (Dishwasher Repair)
by saegsblair 9/19/2013 5:45:58 AM(UTC)
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 9/14/2013 9:47:52 PM(UTC)
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 3/30/2013 4:25:14 AM(UTC)
GE Profile Dishwasher - Constant Buzzing (Dishwasher Repair)
by diydaddy 1/25/2013 9:49:05 AM(UTC)
GE Profile Dishwasher will not fully drain (Dishwasher Repair)
by springerider 1/6/2013 6:30:22 PM(UTC)
